AIR CLEANER PICS!!
#92
RE: AIR CLEANER PICS!!
ORIGINAL: twofish
PigInaBlanket
I now have HD smooth air cleaner cover ready to modify like yours.
So when you removed your black faux carbon fiber trim ring on your football
did you use the same adhesive that was on the trim to attach to the new air cleaner?
Does the ring lay flat like it does on the football?
Thanks
Selling this one soon.
PigInaBlanket
Thanks
I rushed becauseI wanted to hurry up so I didn't remove all the old adhesive off the trim ring then used 3m car trim adhesive tape to put it back on. I got the adhesive tape from Pep Boys, it's the kind with the red backing you peel off. It laid pretty flat but still stuck up a little but after being on a while it must have softened up and laid flat finally. I could have done a little better by removing all the old adhesive first instead of being in such a rush but as of now it is on there flat and looks pretty good if I do say so myself.
#93
The mods are finally complete. I haven't had it on a Dyno yet, but that's in the works. The bike pulls hard thru the entire range and throttle response is very impressive. They should've had the Heavy Breather on as stock, but that's my opinion!
[IMG]local://upfiles/50983/E21766BB0F1D4E20A182EA64A7A0A01C.jpg[/IMG]
#95
Same as Chipstah
Lots of air flow and rain protection.
Fish Video
http://s132.photobucket.com/albums/q5/twofish8/?action=view&current=MeatFish.flv
