CAN NOT GET THE BACK TIRE OFF!!! *got it off
Old 12-29-2007 | 12:28 AM
piniongear's Avatar
piniongear
Default RE: CAN NOT GET THE BACK TIRE OFF!!! HELP~
ORIGINAL: JRK5892
man! so i have the bike up... follewed the book to the T... have the bolt removed... tire dropped down... but the axel will not come out! i even tried a block of wood and a hammer to see if it may have just been stuck! what am i missing! i need to get the tire off the bike. please help me out!
This problem of getting the axle out happens a lot. The reason it is stuck is because of rust inside the spacer sleeve that sits between the bearing races inside the hub.
All you can do is pound the axle out of the bike using a brass rod of about 5/8 inch diameter against the end of the axle. The reason for the brass rod is to protect the axle threads.
The axle spins because what is holding the axle is the spacer tube between the bearings inside the hub. The axle and spacer are stuck together, but rotate because the bearings turn. This spacer you will see when you get the axle removed.
Shoot some penetranting oil down the axle at both ends. The bearing inner races will most likely keep it from reaching the spacer, but it may help get the axle moving.
Just pound the **** out of it and it will come out.
When you put the axle back in, cover it and that spacer sleeve with Anti-Sieze and you will not have the problem again.......pg
Old 12-29-2007 | 12:30 AM
2007fxdc's Avatar
2007fxdc
Mud, on the left side of the reply box, click more smileys...
Old 12-29-2007 | 12:46 AM
JRK5892's Avatar
JRK5892
GOT IT!!! man that was a @#$@! to get off! ooh well... the winter mods have begun... whole new look to the bike after this round! rims powdercoat, tons of other powdercoat,re wrap exhaust, new signals, twisted spokes, lowrider dash with tach... oh there is more!! had to get the (@#&$ rear wheel off to start it all! thanks guys! ill post pics when done
Old 12-29-2007 | 12:50 AM
2007fxdc's Avatar
2007fxdc
We knew you would get it. It's a bit unnerving to whack anything on your bike that hard isn't it?
Keep us posted with pix! I just had to spend $700+ on new tires for the wife's Jeep so my fun money for mods is gone for a while. I've been a little out of control lately anyway.
Old 12-29-2007 | 01:00 AM
mud's Avatar
mud
muderator
ORIGINAL: 2007fxdc
Thanx Greg. Found it.
warren827
Wheels/Tires
05-06-2015 11:38 PM
ddellostritto
09-22-2011 09:22 PM
JT-FXDL
06-21-2011 06:41 PM
rdondes
10-04-2010 08:40 PM
fastfxrs
08-16-2008 10:02 AM
