1550 kit for 06 dyna
Dont know if anyones had this done to an 06 yet , but mines in the HD SHOP AT THE MOMENT, but there is a problem !!! the 06 model has different cam plates , so the upgrade is designed for pre 06.
The shop has said they are waiting on part number info from harley hq ,but because of xmas things are slow .
Any info appreciated
RE: 1550 kit for 06 dyna
ORIGINAL: snowyhog
They do if the kit 1550 cams wont fit . The 1550 re map is with the kit !!!
They have said the 06 camplates dont except the 1550 kit cams /rockers
We are talking full kit here not just barrels/pistons
oh, you mean the H-d 1550 kit. i didnt think anyone actually fell for that.
$200 pistons and gaskets with bore charge = 95 inches. plenty of can choices that are drop in and work well. but you wont tune it with a download!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Yes, the cam plate, cams, chains, and adjusters/tensioners are all differant. None of these parts interchange between the engines.
The 1550 kit as supplied by HD carries a differant PN for the '06 dynas, that's PN 29874-06. It includes 203 cams.
Sounds like your dealer purchased the wrong kit for you.
There is also a download available to match this kit.
Personally, I would not use the kit. I would choose the parts I wanted to make it run the way I want it to. But that's just me.
Do you know about the kit installation discount from H-D? They say it's for the 103 kit, but list the 95 kit part numbers.
