HD smart security system
RE: HD smart security system
It will only take you a few hours to install, butthe alarmwill not work until you get to the dealer and have them assign the fob key to the alarm. While your at the dealer I recommend getting a second fob and also getting that set to the alarm. Also make sure to follow the instruction and to enter in your own passcode into the TSSM so you can start the bike if you ever lose your fob key.
Chris
Chris
When I bought and installed mine it only came with 1 fob, I had to buy the second. I said a couple of hours, but that time is dependant on your knowledge of the bike. If you know your way around the bike you can be done in under an hour easy. All you do is swap out the TSSM and install the siren, if you haveone, and put it back together.
You will need to marry the TSSM to the bike before it will start so make sure you search the forum.There are several topics in the tech section on how to do this as it does not come with the instructions you get with the alarm. It is easy to do, but will take about 20 minutes.
ORIGINAL: CCPD
...but the alarm will not work until you get to the dealer and have them assign the fob key to the alarm...
Chris
Chris
I foolishly thought I'd be able to figure it out from the documentation (yeah right) or from my riding buddy who has the same system on his FDXWG. Unfortunately, his 'just works' and he doesn't know how or why mine won't. [&:]
Anyway... I guess it will sort itself out sometime soon.
ORIGINAL: grandpawmoses
My FatBob came with the factory installed alarm & fobs but not the smart siren. If I should decide to add it, is it "plug & play"?
ORIGINAL: stagolee
Hmm... I think that might be the missing link with my Smart Siren II. The sales person didn't know a lot about the system and just handed me the FOB and the pager and wished me luck.
ORIGINAL: CCPD
...butthe alarmwill not work until you get to the dealer and have them assign the fob key to the alarm...
Chris
Chris
