Tank Lifts?
RE: Tank Lifts?
ORIGINAL: Dynamite17
What are the reasons to install a tank lift, anything functional? More cooling to the engine?
What is involved with the installation?
To install, loosen the rear tank bolt but do not remove, remove the front tank bolt, install lower end of tank lift bracket to original mounting point on frame and reinstall tank to the top of the tank lift bracket, tighten rear bolt, and you're done. Oh, forgot the last step - take pix and post on hdforums.
RE: Tank Lifts?
ORIGINAL: mikeurig
Hey Mud, where did you get the key fob from?
A few years back I decided to make up some new business cards
with keyrings.
This one, I embedded the key during casting (hard resin).
I was on a jobsite a few weeks ago in my truck
and lost the thumb.
Went back the next day, and someone had run over it
and cracked the key out.
I'll make another key when I pick up from more resin.
Gotta buy two gallons at a time.
So I switched over to the ooga booga for now.
mud
RE: Tank Lifts?
Tank lifts - WHY FFS???
Sorry. Just don't get it. It naffs your fuel light up & gets you p'd off earlier each time, lessens bar clearance & stretches you lines underneath.
I reckon it's the Kings New Clothes all over again.
Now those Stiff Little Fingers...were'nt they a punk band back in the 80's?
RE: Tank Lifts?
I made mine at 1 1/4" and I've made 1 1/2" and 2" lifts. I went as low as possible to achieve the look without affecting the fuel gauge too much. I can take mine down to "E" and it takes 3.8 gallons to fill on a 4.8 gallon tank. I like how it opens up the top of the heads and gives you more of a stretched & raked look even though you didn't change the frame geometry. I think it gives you more air flow over the heads to help dissapate heat also. The fuel pump has a "sock" on the intake that lets it use all the fuel in the tank. You would lose a bit of capacity with the cross-over tube being raised but you shouldn't be pushing your luck that far anyway.
RE: Tank Lifts?
My bike definately looks better with a 2"tank lift installed. I have 3.5" straight risers with mini-apes over them. That combination of partsput mytop-clamp mounted speedo up real high in relation to my dash and tank. After some measuring and getting in touch with Jackyl, the 2" lift perfectly aligns the top ofmy dash and bar clamp. In effect .... I actually returned my dash/tank to normal by raising it roughlythe same amount I raised the risers.Beyond that,I thinkthe lifts make the majority of bikes they are installed on look better.
PsTaN
PsTaN
RE: Tank Lifts?
I have a 3" lift on my 06FXD. When the "low fuel" light comes on, I have approxiamately 100 miles left on a country ride. When I hit the big "E", I have approximately 65 miles left.
If I run her outa gas, it takes exactly 4.8 gallons to fill her up.............. Don't ask
I like the tank lift a lot, especially looking at the setup when I am sitting on the seat. I also think fillups are easier.
I don't care if you get a tank lift, or not.
DougJ
DougJ
