V&H Fuelpak or PCIII with Big Radius??
Hey all,
I just pulled the trigger on the V&H big radius pipes. Now, next question is, which would you all recommend, the V&H fuelpak or the PCIII?? I think I will be running the big sucker stage 1 a/c with these pipes as well. So, what are the major differences between these two products?
Thanks all!
Cheers,
Adrian
Thanks all!
Cheers,
Adrian
RE: V&H Fuelpak or PCIII with Big Radius??
I think either one would work - depends on what you want to achieve now and in the future. If you just want to get your AFR in a good range the Fuel Pak will do fine - if you want to wring every ounce of performance out of your bike via Dyno tuning or have plans for future engine enhancements the PCIII would probably be a better alternative as if offers much more adjustability across RPM's and throttle positions. I put VH pipes on my Dyna, an SS air filter and got a PCIII with a decent map on it for my combo from Fuelmoto. I've been very happy with the results.
Tons and tons of info on this subject in past threads - lots of pros and cons to each and I wouldn't rule out the HD SERT either (especially with 20% off at many dealerships like Zanotti's). My experience, you get what you pay for, and the more you can think 'down the road' as far as potential other mods (different pipes, engine, etc), the more likely you'll save money in the end, even if you spend a little more up front. Just be aware some of the fuel management opinions tend to get more like the ford vs. chevy arguments.
If it was me, I'd go find your local tuner with the best reputation and experience, and ask what he'd recommend. At least that's what I already did, and am extremely happy with my SERT (to go with SE stage 1 intake, K&N filter and V&H short shots) and eventual dyno tune after engine was broken in.
ropd0184
Exhaust System Topics
01-07-2008 05:28 PM
Todd Vikan
08-05-2006 04:59 PM
