Paint Set
RE: Paint Set
The paint set will bolt up, but they are not the same.
The 07 FXD has the speedo mounted to the bars, so you only have the gas cap and gauge on the gas tank.
The 07 FXDC has the speedo mounted on the tank, as well as the ignition switch, gas cap and gauge.
It would be somewhat costly to change from one tank to the other because of the new hardware needed.
RE: Paint Set
ORIGINAL: wolfydude
Jmpan,
Many thanks for your help you have saved me a lot of money and problems,i was buying a paint set from a guy on Ebay and he said it would fit my model ok,he must of made a mistake.
Cheers Again
Wolfydude
Jmpan,
Cheers Again
Wolfydude
TeeJayEe
11-28-2016 04:45 PM
