05-06 FUEL TANK FXDWGI
Old 12-11-2007, 06:48 PM
jojobrit's Avatar
jojobrit
jojobrit is offline
6th Gear
Default 05-06 FUEL TANK FXDWGI
Does any one know if an 05 tank will fit on an 06 dealer says it should? Does any one know for sure? Thank you
Old 12-12-2007, 05:30 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Default RE: 05-06 FUEL TANK FXDWGI
If they are both set up for fuel injection, they both should fit.
Your dealer is your best source for this info. You would think they could tell you definately whether or not the tank sare interchangable.
Seems if they were to take a second and look up part numbers for the 05 tank, then the numbers for the 06 tank, they could then compare the numbers to see if they are the same.
Please feel free to hit your ctrl and p buttons to print this if your dealer needs to use it as a guide sheet.
Old 12-12-2007, 06:31 AM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Even though the Dyna frames changed from 2004/2005 and the 2006 models, the tanks should fit with no problem. I bought an e-bay tank off a 2006 and it bolted right up to my 2004, no fitment problems at all.
Old 12-12-2007, 08:01 PM
jojobrit's Avatar
jojobrit
jojobrit is offline
6th Gear
Thank you for the replys this helps alot great forum
baldric
09-29-2015 04:13 PM
paullavery
01-25-2012 12:28 AM
cliffd
12-03-2010 08:37 AM
must8657
08-27-2009 09:28 AM
OkieRoadWarrior66
04-06-2009 01:24 AM
Quick Reply: 05-06 FUEL TANK FXDWGI
