V & H Straightshot HS slip-ons for '07 Street Bob
I've recently fitted a pair of Vance and Hines Straightshots on my '07 Bobber. I havent done any other mods. It runs fine, except at high revs when it staggers but I have to really tanking it to make it do this.
I know you should fit a Fuelpack, but my local HD dealer suggested a power commander but quoted around £550 to fit it. They reckoned the V and H fuelpacks were no good for '07 Dyna range.
Any thoughts ?
Any thoughts ?
RE: V & H Straightshot HS slip-ons for '07 Street Bob
Dealer is FOS!
So the Dynas now have a "range?" Umm....range of what?
Contrary to what a lot believe, slip-ons, particularly ones as benign as V&H SS's, should run fine (however lean) with no other mods. The stock ECM will compensate some for the higher air flow out, and being a closed-loop system (feedback from the O2 sensors to the ECM for compensation and adjustment of conditions), you should be fine for most normal running around. If you are still skiddish about running so lean, get the HD ECU flash for Stage I. That should cure the staggers at high revs. If your dealer doesn't want to do it, or says there is no such thing, go to a different dealer or Indy shop. Your dealer is feeding you BS and trying to take your $$$
However, with just slip-ons you're cheating yourself and the bike out of 10 HP,some torque, and a really smooth throttlefor not getting a higher flow air beather and filter.Get one. Ness BS, SE, many out there for decent prices, particularly on Ebay.
After installing a higher flo a/c with more air in and out,you really "should" get some type of fuel management device to richen the mixture. Fuelpak works awesome on my 07 Dyna Bob with Straight Shots, and a Ness Big Sucker A/C. I personally know 3 people with 2007 model Dynas that successfully run V&H pipes and the Fuelpak.
PC is a great unit too. But way more money, and unless you plan on doing more engine mods further on down the road, more than you need. Fuelpak is easy to install, easy to program, and makes the bike run great. For $200 (US) you can't go wrong.
Ditto, basically, what flynavy said.
V&H doesn't recommend fuelpak with the stock air cleaner. So, if you decide to install a fuelpak, PCIII, or any of the others, I suggest you look into a stage 1 a/c as well. Both Flynavy and I went through this exact same setup together a few weeks ago. We came to the conclusion that fuelpak is less expensive, easy to install, and sufficient for a stage 1 setup on an EFI HD. There are some here that disagree with that and won't even use a fuelpak to wipe their behind with. It's not a tunable device but it just adequately enrichen your air/fuel mix specific to your pipes, engine, and a/c enough to enable your motor to breath and run better and give you a little more performance output at the same time. If you own and can turn a wrench and a screwdriver, look to purchase the parts online and install them yourself - you will save a lot of money and won't have to argue with your single-minded dealer. PCIII is a nice device and is worth it if you plan to fine-tune your bike and are willing to spend money and time on a dyno tuner to work it out but, IMO, it's overkill if all you want is a stage 1 that is running okay.
I paid $269 for my PCIII and it came with a canned map for my CS Slip-ons and AN BS. I have now installed Rinehart slip-ons and it runs even better, with the same map. Not sure what that means, other than I'm gonna leave it alone and run it.
ORIGINAL: 07 StreetBob
ORIGINAL: funguseater
Any thoughts ?
Any thoughts ?
other than that what navy and 2007fxdc said ...
I know you should fit a Fuelpack .....
nashbk
05-11-2012 09:57 AM
