Reflector Fiasco
Reflector Fiasco
So after months of reading about removing the reflectors, I finally got to it. I used the fishing line to take the reflector off, no problem. Then used Goof-Off to get the adhesive off, but when the smoke cleared my fork looked like junk. I think the clear coat came off as well so now I have all these blotches in that area. I like the way it looks with no reflector but now i think I am gonna have to put it back on just to cover it, unless there is a way to buff out the front forks so that is at least not so noticeable. Bummed! Any ideas?
RE: Reflector Fiasco
Thats the close up above. Its as bad as it looks. I think Goof off is too strong or something. The bad part is that i had a heat gun right next to me and if i would have just heated it and pulled it off it probably wouldnt have made a mark. Ill keep trying to polish it but it looks like it is what it is! Im not touching the other side till I figure this out and I am not going near the fenders!
I used lots of heat from a hair drier and cleaned off the remaining sticky stuff with WD-40. Nothing like what I see in your photo. It appears to me you have have a few choices about ways to fix it. You can sand the lower down with some fine sand paper and re-clear.....or you can sand with even finer sand paper and polish both lowers....or you can have them powder coated....or you can re-install the reflectors. If it was me, I would try using more heat on the other side and see what the results were and then go from there. I do warn about using a heat gun as they tend to get VERY hot and can have adverse effects as well. Hair drier is much more forgiving. It just takes longer. I don't think goo-off was the culprit. I think there might have been a defect in the clear.
Maybe something like Scratch-X will buff it out. I got good results using it on some light scratches in the clear-coat on my Vivid Black.
If not, look in the recent post Mud started about Fifty Dollar or less mods. In there, Tommay has a link to his instructions on removing the clear-coat and polishing his sliders to a chrome-like appearance. Looks great.
