Suggestions for white walls for street bob?
Old 12-09-2007, 08:41 PM
pennetta's Avatar
pennetta
pennetta is offline
Default Suggestions for white walls for street bob?
Is the wide tire kit from HD include a specially designed tire to fit the stock rim or is it a standard size? Also I like the wide white wall look, assuming the 180 rear kit, what tires are available?
Old 12-09-2007, 08:56 PM
VenturaChop's Avatar
VenturaChop
VenturaChop is offline
Default RE: Suggestions for white walls for street bob?
the widest white wall is a 150 and you have to go with a 16 inch wheel.///....no white walls for a 17 inch wheel
Old 12-09-2007, 09:01 PM
VenturaChop
im in the middle of doing it so any questions go ahead and ask
Old 12-09-2007, 09:05 PM
TheeBoy's Avatar
TheeBoy
TheeBoy is offline
Hey ventura, you end up going with the avon venoms? can't wait to see it. It's going to be interesting to see the whitewalls/drag bar setup, I can't imagine it, but i am sure it would look pretty killer
Old 12-09-2007, 09:08 PM
lolife's Avatar
lolife
lolife is offline
ORIGINAL: VenturaChop
Ditto..................... . .. . ................. . . .................
Old 12-09-2007, 09:10 PM
VenturaChop
yeah man i have my hub at the lacers house....but its going to be done after the holidays.......... i got the avon
Old 12-09-2007, 09:17 PM
CraigC's Avatar
CraigC
CraigC is offline
No whitewalls for 17" wheels. There is a 170 for a 15" though, which is the direction I'm headed in.
Old 12-09-2007, 09:33 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
The SE Dunlop is a special tire designed to fit on a smaller rim but, you can fit regular 180 tires on there like the Metzler me880.From what I've seen though the Metz and a few other tires don't look as wide as the dunlops.They don't make white walls in the sizes for the Street Bob so there only two options, 1 convert to 16" rims or 2 paint your stock sized tires.There was a Forum member who actually went the paint route early on and it came out suprisingly good.
Old 12-10-2007, 05:30 AM
PigInaBlanket's Avatar
PigInaBlanket
PigInaBlanket is offline
Check this out
http://www.mbzponton.org/valueadded/other/tirepaint.htm
I'd be interested to see pics of a Street Bob with white walls if anybody has them.
Old 12-10-2007, 08:12 AM
lolife's Avatar
lolife
lolife is offline
It would be worth a shot................................ . . . .......................... . . ..............
Quick Reply: Suggestions for white walls for street bob?
