Defintive Position on the Inner Primary Bearing Issue 06-08
#31
RE: Defintive Position on the Inner Primary Bearing Issue 06-08
when my 07 super glide had 300 miles on it i had the dealer put the fowards on and the inner and outer chromecases on ,when i it 5000 the bearing was toast now i have 10000 and all is well for now.i still have the old silver case with the 07 bearing in it.
who knows what year inner case i have now,might be the 06.
#32
Good Morning Folks,
I've been looking for all the information on this subject that I can find; same problem still going on. I'm on my third set of bearings, it ate the clutch hub bearing at the same time.
Here are the threads that I've posted on, I hope that this helps keep the information in one place for all that need it:
https://www.hdforums.com/m_2244261/tm.htm
https://www.hdforums.com/m_2268712/tm.htm
and I'll copy this to: https://www.hdforums.com/m_2540619/tm.htm
The 06 FXDI, has around 20K miles on it and less than 1K miles on the last set of bearings and already I'm woundering if I'm starting to hear the "throw out bearing" noise.
Hopefully, I'll get enough miles on it before the warranty runs out, 4/24/08.
Best wisdhes,
Pixs
Best wisdhes,
Pixs
#33
ORIGINAL: Pixs
Good Morning Folks,
Best wisdhes,
Pixs
Good Morning Folks,
Best wisdhes,
Pixs
It is totally wierd, this tranny thing doesn't seem to have any real pattern to it.
I think it is a quality control issue on the assembly line, but HD ain't talking.
DougJ
#34
ORIGINAL: DougsDyna
DougJ
[/quote]
You're welcome, someone had to do it. Now you should move the whole thing to the primary etc. section so that folks can find it.
Your last line is telling, we all think but want to know. What is needed here are real facts that will help solve this problem. It looks to me like JBE has found something no one else has, I'll bet that the inner primary cover and the tranny cover needs to be changed as well.
Best wishes to all, even those of you that don't have this problem,LOL,
Pixs
#35
well i take that back i am hearing the sound comming back now after some long rides from when i last posted.it is going out again.last time it wentout was so load that when i took it in and started it for the service manager as soon as i started it he said turn it off i hear it.its not that bad yet.
just under 11,000 miles on the 2nd one,bike a 07
#36
Mine is currently in the shop. Seems the ipb 'race' is the problem. They have to replace about 3 parts. I called HD headquarters prior to taking it in just to make sure. Luckily I'm still covered under warranty. Once I get the scoot back I will re-post with all that was done to it. Thanks for the info on this gents, was a HUGE help.
Ride on!
Ride on!
#37
#38
Race, Inner bearing, retaining ring, roller bearing replaced. The race had backed out. 'common problem' per my dealer. Well, at least they replaced it under warranty. I have 14k miles.
Hope this may help someone else. Oh and Phil, i did get the 'everything is ok letter' as well.
#39
ORIGINAL: route2null0
Ride on!
Ride on!
Pisses me off when the dealers think they can just screw us over on warranty work especially.
#40
Here is everything that was replaced on my 2nd time in for this:
11105 o-ring
11161 retaining ring
11289A o-ring
11573 o-rong oil spout
12074 oil seal
16583-00A bushing, dowel
26072-99A gasket, oil pan
27444-00Y o-ring
34091-06 race,inner bearing
34746-06B transmission case sub assb
34917-06 gasket, trans top
34934-06 gasket, primary housing T
35122-06 output grear assy,driven
35607-06 gasket,transmission,cas
35654-06 gasket, transmission, bear
36805-06 gasket, transmission side
60547-06 gasket, primary cover
60789-06A primary housing
63869-06 gasket, tower
786A bolt,seal
8963 needle bearing
8967 ball bearing, double row
The first time the parts list was not nearly this long. It was in the shop for 16 days this time and only 2 the first time. So far in the shop twice in one year and 18,000 miles.
11105 o-ring
11289A o-ring
12074 oil seal
27444-00Y o-ring
786A bolt,seal
8963 needle bearing
