Bend brake line or not?
RE: Bend brake line or not?
Replacing the brake linemay be a chore simply because bleeding the brakes can be a PITA. I tried and tried and tried with no success until I invested in a vacuum pump.
There are many posts here about folks who went from buckhorns to mini-apes or risers and had to slightly bend the brake line to extend the length. A couple of these have broken in the process.
You're takinga chance. I would have to spend the few extra bucks and do it right with a properly fitting brake line.
I have changed bars many times on several bikes. You can bend the line no problem. Try to use larger radius bends, no kinks, should not bend in the same place more than once or twice, that's when the steel will harden and crack. You would have to bend a line back and forth in the same place several times to crack it.
ORIGINAL: Trotter
It would have looked better also Did you get any ride time yesterday ? You should have come down I fell off the roof [sm=lol.gif]
Especially if the wife can use it[sm=outcold.gif]
Did about 190 miles, via a new shortcut through Franlkin, WV. Rt 33 from Franklin to Harrisonburg, VA is one windy, steep son of a gun.[sm=bounceybounce.gif][sm=bounceybounce.gif][sm=happy046.gif][sm=happy046.gif][sm=happy046.gif][sm=happy046.gif][sm=happybounce.gif] Glad I got home!!![sm=hail.gif]
Did you get the lights up??
DougJ
