fork gaitors
Old 12-29-2007, 07:31 AM
MasterGunz's Avatar
MasterGunz
MasterGunz is offline
Default RE: fork gaitors
Chipstah: Did you have to modify your fork gaiters? When you had them installed originally did they fit over the stock lower end caps?
Old 02-07-2008, 07:27 AM
risdo's Avatar
risdo
risdo is offline
ORIGINAL: str33tb0b
Yep, I have the same question.
Also... is that some kind of clamp you put over them, at the bottom?
Thanks!
Old 02-07-2008, 11:46 AM
Chipstah's Avatar
Chipstah
Chipstah is offline
ORIGINAL: risdo
ORIGINAL: str33tb0b
Thanks!
Yes - they needed to be trimmed/cut down to length, and were a bit tight, which was good IMO, and they fit w/o the end caps and are held with the SE fork brace (powder coated) - think you should be able to see it in the post above pretty well and maybe here, too:
Sorry str33tb0b for taking so long to reply, tried to answer your pm of a while ago a number of times and look you up on the forum member search, but kept getting emails kicked back saying no such user (???) and promptly forgot to check this thread. Oops!
Chip
Old 02-07-2008, 07:05 PM
TARTAN2's Avatar
TARTAN2
TARTAN2 is offline
Same as mine
ED - Got mine over the dust covers - bit tight but thats good and am going to trim the tops cause I think they will look better - will post pic when I'm done.
Old 02-07-2008, 07:23 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
I used a plastic tooth brush end and hair spray... i know it sounds weird... that is how i did it... same way you get grips on your bike... the tooth brush end will not scratch anything but will still allow you to pry them out a bit causethey are pretty tough, the hair spray will lube it up and then dry not allowing it to slip off... then you just get a damp cloth to wipe off the excess... neat trick using hair spray... i use it whenever i got to get something rubber on that i do not want to come off... WOW could have gone in a total wrong direction with that one! but ya i have mine pulled down so just a thin layer of chome shows though...
ORIGINAL: SPECIAL ED
Hey Joe yours look a little different than mine towards the bottom.Did you manage to stretch those over the top of the fork sliders?
[IMG]local://upfiles/26534/3970837ABAE54A80A6277AAF535A602A.jpg[/IMG]
Old 02-08-2008, 02:59 PM
risdo's Avatar
risdo
risdo is offline
Chipstah, you mentioned taking the brake caliper off when sliding the forks out of the triple tree.
Did you have to bleed the brakes afterward?
Old 02-08-2008, 03:51 PM
Chipstah's Avatar
Chipstah
Chipstah is offline
ORIGINAL: risdo
Hmmm.... don't remember saying that!
Old 02-08-2008, 05:42 PM
TARTAN2's Avatar
TARTAN2
TARTAN2 is offline
Unbolted mine and tied them to the frame legs to keep them out of the way . JUST DO NOT PRESS THE LEVER WHEN THEY ARE OFF !!! Better still stick something thick between the pads - mistakes happen.
Old 02-08-2008, 05:50 PM
Punty's Avatar
Punty
Punty is offline
Just cut the ends off and work them over your Dust caps. Its a PIA but well worth the effort.
Old 02-08-2008, 06:09 PM
Chipstah's Avatar
Chipstah
Chipstah is offline
ORIGINAL: TARTAN2
[sm=exactly.gif]
[sm=goodidea.gif]
Quick Reply: fork gaitors
