kuryakyn Pro-R Hypercharger
RE: kuryakyn Pro-R Hypercharger
I've got the pro R on my 07 WG. I put it there not for the performance (if you search it really won't do much) but for the looks. Personally I like the look it is different from the norm. And personally I think that the function with the butterflys is kind of cool. Ok all Hypercharger haters flame away I can take it.
I've always thought they looked cool I just couldn't take putting something on that cost more and performed worse than the Screaming Eagle air cleaner I have now.I wonder if it could be installed without the butterflies as sort of a cool looking air cleaner cover?
Jabroni, I haven't seen anyone post anything detrimental that used any specific scientific methods to prove or disprove performance gains (like metering flow inside the case at 50 MPH for example or putting the bike on tuner while running on the road. Most of the dialog on suction vs. non-suction sounds logical but seems to be just opinion.
I have one on my 05 Superglide and it runs strong with no pings, stuttering etc....so who knows whether it does what Kury says it does.
have one, was on the bike when I bought it - older (non pro). changed the element to a k/n for performance. charger is show&go. yes different.
either take out the flies or remove vacum- but still would have to fix them in "open" position"??? so just remove em.
personally I likethe flies working.[8D]
have one on mine and never had a problem although the butter fies are open all the time I believe it gives a little more power but even if it didn't I love the looks. I have almost 40 thou. on mine mileage is in the mid 40 's and will run 110 anytime I want also hae ss510 cams
[IMG]local://upfiles/5757/734E4EBDC7A74A9BBB107C8B1EF58107.jpg[/IMG]
