07 WG Bad Battery???
532 miles, mostly short trips recently. Did a firmware upgrade from PCIII usb as per jammie due to Delayed starting after warm. [ yes did the hit the on/off started buton trick] After upgrade to the new 2.2.2.0 [ [ right?] She threw a code "P1004" System Relay Contacts Closed EFI . Could have been me screwing with the lap top while conected to the bike ?
Clearened the code. Did a few re-starts and code search thing. NONE showed up. [ but now gives me all the part numbers displayed in the osomoter] Screwed with it somemore , re-starts [ lights up after 3 to 5 turns] .
Short ride about 10 minutes [local] . Home quick re-start o see if Jammies fix worked [ aaahh sort of]
Today battery very low no fuel pump sound, yet engine would crank over a little [ slow]
put the battery tender on [ only 750 mil amps ?] after a few minutes fuel pump sound came back. but still no fire up. [ very slow. All lights work ] Has theTSSM security system.
Really Hate the FI Harleys. Give me a carbed Bike anyday.
RE: 07 WG Bad Battery???
See thats why I like this place and the guys here.
I called a casual friend at my stealer. He said the same thing Tighten the battey connections.
I did , they were a tad loose[ I was able to turn them easy with a screw drive., guess I didn't tighten them all the way when I put on the Pig-tails for the battery tender]
So this morning with I hit the ing. switch and the kill switch, heard the fuel pump going like hell, hit the starter. Holly $hit maybe 3 revolutions and she fired up. Now normaly it would take a few more due to the PCIII.
I just hope it was me doing to many starts and screwing around with the read out.
Gonna do a lock or Star washer on the battery.
IOU guys one.
Thanks again
IOU guys one.
Thanks again
