For all you "do it yourself"-ers!!!
RE: For all you "do it yourself"-ers!!!
OK,
I think I found it myself........Duplicolor
http://www.duplicolor.com/products/paintshop.html
supposed to be "easy" and really cheap to do.....of course the hard part is always the prep........
Looks like it's $20 a quart at JEGS....quart of primer, quart of color and quart of clearfor $60.00 no reducing or mixing...limited colors.......
Paint Shop Finish System gives you everything you need to create a high-quality DIY finish – primer, color and clear. It’s a high-quality lacquer system designed for automotive and motorcycle applications. Paint Shop is easy to apply, dries quickly and can be buffed to a brilliant smooth finish. Paint Shop is a ready-to-spray system, so no mixing or reducing is required. And with no re-coat window, additional coats can be applied at anytime.
