16" rear wheel to an 18"
I am buying new wheels for my 96 FXDL, and I am switching the wheel size. I have just changed my front end over to a WG front end and am going to use a 21" front wheel and a low profile tire. I was thinking about using a 18" back wheel (it came O.E.M. with a 16 - but I have several inches of clearance). I was wondering if any of you guys had switched to a larger rear wheel and if you liked the results. Would lvoe to see a pic of the larger wheel and how much more it fills up the huge void between the wheel and fender. Thanks
Swampy
Swampy
RE: 16" rear wheel to an 18"
I dont have any pics.....nor have I done this.............. . .but I can tell you it will work......and it will look good......fill in some of that space.............good luck......................and post some pics.before and after..................................... LOLIFE............................................ .........
