removing stock hand grips?
11-23-2007, 03:05 PM
Howdy all,
is there a way to remove the stock rubber hand grips from my street bob without cutting them off?
11-23-2007, 03:08 PM
RE: removing stock hand grips?
There very well may be Daggs, but it involves way too much effort for the end result.
They cannot be safely re-used, so cut it off.
If you decide later to put stock grips back on for whatever reason, you can find them for a dime a dozen on ebay or other places....
11-23-2007, 03:53 PM
just cut it aint worth much
11-23-2007, 03:54 PM
You can save the right side but not the left(it's glued on, cut it off) I don't know what else you can do.
11-23-2007, 05:45 PM
Are you sure it's glued on? I assumed mine were, but alas it was not. Came right off with the removal of the switch housing.
11-23-2007, 05:49 PM
Yah mine clutch side was not glued on to well, it was stickey but I was able to pull it off without much effort. after seeing how cheap they were though I would not want to reuse either.
11-23-2007, 06:47 PM
They aren't on all that good. If you get a screwdriver (careful) under the grip and lift a little, should break it free enough to twist and slide off.
Probably best to just put ya some new ones on.
DougJ
11-23-2007, 07:07 PM
Mine was glued on pretty good. Cut it off not worth saving the stock grips anyway.
11-23-2007, 08:27 PM
I've heard the screwdriver trick and some WD-40 will do the trick.
11-24-2007, 12:22 PM
I twisted the left grip as hard as I coulduntil the glue broke (almost broke my hand too)then pulled it off. You could also try one of those strap wrenches to twist it off.
