lower front fork scratches
Old 11-15-2007, 12:07 PM
58nluvnit's Avatar
58nluvnit
58nluvnit is offline
Default lower front fork scratches
Is there any way to either buff out or maybe use steel wool to get scratch marks off of the lower forks on my 06 streetbobThey are the brushed aluminum type not chrome. Thanks for any help. 58nluvnit
Old 11-15-2007, 12:52 PM
Shaw_2112's Avatar
Shaw_2112
Shaw_2112 is offline
Default RE: lower front fork scratches
Don't know if they've changed but the lowers on my '00 FXST are aluminum. They're clearcoated, treat it the same way you would paint scratches. Clear touch-up or scratch-x. If it's a deep scratch into the metal it'll have to be sanded out. Best thing to do at that point would be to have them pro-polished...
Old 11-15-2007, 01:43 PM
Lumpy63's Avatar
Lumpy63
Lumpy63 is offline
The lowers are actually painted, with a clearcoat paint applied over top. I just stripped mine down to the aluminum and had to get the lowdown before doing it.
As stated: Get some clear paint and a fine brush and fill them in. Unless the lowers are chromed, it's a biotch if that clearcoat gets scratched. Filling it in might not make it look like new again, but it will prevent the clear from turning any more, or getting uglier.
Old 11-15-2007, 01:44 PM
powdercoater's Avatar
powdercoater
powdercoater is offline
Shaw is right, stock fork legs are clear coated. If you have to sand or buff through the clear coat you're better off removing the legs and getting them polished, chromed or powder coated... I vote for powder coat! If you get them polished you will have to keep them polished yourself since they won't be protected with a clear coat any longer.
Old 11-15-2007, 02:47 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
i did what Ed did... they look amazing!!! i had a scratch in mine and figured this was the best time to make em black!
[IMG]local://upfiles/26534/5272EF0A1F6D44F69EFB79C1AA0C4D88.jpg[/IMG]
[IMG]local://upfiles/26534/119BFF2BA2494FD790F2DC107A610ABB.jpg[/IMG]
[IMG]local://upfiles/26534/E5C5088E88F044EC8020C084C0443149.jpg[/IMG]
[IMG]local://upfiles/26534/93FD3655A191490BBDCF5656E1651479.jpg[/IMG]
Old 11-15-2007, 08:23 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
Joe,your sliders look great,I hate to say it but you need to paint those rear air shocks black to balance it out.And polishing sliders yourself isn't too tough either I've done that too it just a bitch getting the clear coat off.If you paint them you can get away with just roughing the paint up real good.
Old 11-16-2007, 02:15 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
already in the works ed already in the works! ha ha ha i am looing for a new set of turn signals so i cna just do it all at once and be done with it
Old 11-16-2007, 05:00 AM
Lumpy63's Avatar
Lumpy63
Lumpy63 is offline
ORIGINAL: JRK5892
I have to agree: Those sliders look outstanding with the black color scheme. However, what I think really sets it off are the fork boots..... The older Harleys had black lowers and the boots are retro as well. It just fits....
Old 11-17-2007, 01:00 PM
SPECIAL ED's Avatar
SPECIAL ED
Good luck, the turn signals were the hardest thing to paint for me.I couldn't get the Epoxy to look good and stick at the same time.This is where I learned about the recoat instructions for Epoxy.I ended up using regular Krylon because I didn't have the patience for waiting weeks to build up coats of Epoxy. If I had it to do over again I'd have just left the signals chrome.
Walter Sobchak
Powdercoat & Paint
03-25-2015 07:10 AM
cmonster
04-07-2011 10:50 AM
sdbiker
09-25-2008 05:39 PM
lemhead16
02-10-2008 06:32 AM
Hardly Dangerous
Detailing
04-21-2007 06:48 PM
Quick Reply: lower front fork scratches
