Shift clunk?
#33
RE: Shift clunk?
ORIGINAL: Trotter
Like said before the Red Line Shock Proof will quiet it down... and shift like hot knife through butter...
I thought you told me to put Pepto-Bismol in it, so I put a quart of Bismatrol in the T hole (it was cheaper than the Pepto)[sm=badidea.gif][sm=headbang.gif]
Didn't work too good, eitherGlad I tried it before HD rebuilt it for FREE[sm=insomnia.gif]
Should have read up on it first, huh? http://www.healthcentral.com/peoples...408/56861.html
Maybe you said it LKED like Pepto-Bismol, don't remember but I guess I shoulda known better than to buy motorcycle fluids from a drug dealer[sm=dontgetit.gif]
Oh well, at least things went Kerplunk after that[sm=bounceybounce.gif]
Now, what am I supposed to do with the hot knife and butteryou're talkin about?[sm=forgetit.gif]
Idiot
#34
RE: Shift clunk?
See if you can find a 12 volt toaster.... and have some toast wit yer 12 volt coffeee.... You'll already have the knife and butter.... If ya use too much of the butter on the toast you'll you can drain some of the trans fluid and also have the Pepto..Sounds like yer covered on all ends to meee....
#35
RE: Shift clunk?
ORIGINAL: Trotter
I could probably only make one slice o toast, before having to start the bike
Did ya know 2 pots of 12VDC coffee will run your battery dead?? Just ask the Park Ranger down at Peaks of Otter, that gave me the jump start.
Hey, ever see a 150 lb guy push 700 lbs of bike and gear uphill, after 2 pots of coffee??... Probably pretty funny if you ain't that guy!![sm=badidea.gif][sm=bounceybounce.gif]
Moron
SgtThump
11-20-2007 07:12 AM
