Wide Glide Part Number
I have an 07 Low Rider. I want to upgrade to a 21-inch wheelon the front. I have the smooth chrome spokes already and love the look. Does anyone have the part number for the stock Wide Glidesmooth wheel? I checked surdyke.com and couldn't find anything. Any help is of course...greatly appreciated.
RE: Wide Glide Part Number
The part number for the 21" WG wheel with steel spokes is 43647-06.
It is my understanding this wheel will not work on the mid-glide trees. Sounds like you will either need to change your trees or have a 21" rim laced to your existing hub.
Do a search. There are a bunch of posts about this.
Wide Glide PROFILE front wheel (smooth) is actually #43563-06 and pretty sure its an aluminum rim. I only know because this was the wheel I didnt want. I wanted the "normal" steelwheel. As far as fitting in the mid glide front end, dont think so. Im doing a wide glide wheel with wide glide trees on my 07 Bob and am using the Street bob spacer on the rotor side only to keep the rotor/caliper lined up. Instead of shimming the caliper .090 ive got black bike wheels building mea 21"x 3.5"with the .090 offset to center the wheel. Then i'll just need to cut a spacer for the none brake side.But WG hub is about 1 1/2" wider I believe, just wouldnt fit.
ickmak
06-25-2008 06:32 PM
