Tach signal on 2006 Dynas???
RE: Tach signal on 2006 Dynas???
Thanks
Hole 3 on the ECM plug sounds great.
Thanks again.
PS Have had your wife or girl friend on the back of your 2006 dyna. My wife hates the ride. I rode back there and its got alot od viberation. As a driver you don't seem to feel it but it sure is bad for the passenger.
Whats your thoughts?
Thanks again.
The March 06 issue of V-Twin Magazine has a detailed article on installing a Harley Tach Kit. Its a good article that has detailed step-by-step photos. The kit comes with the tach and twin mounting bracket. It states that the Harley part # is (P/N, 67224-04).
John
PS Also,... The article states the the Harley Tach kit is all inclusive, and states there is nothing to cut, strip or solder, basically just a few screws and you just plug in the new wire harness.
John
When I installed the tach on my Sportster, there were only THREE wires that mattered:
1-Power (took it off the ignition according to the wiring diagram in the factory service manual)
2-Ground (any suitable ground - again, refer to the service manual wiring diagram)
3-Tach/Coil (the wiring diagram showed exactly which lead on the coil to attach it to)
If you guys are trying to do wiring on your bikes without the FACTORY WIRING DIAGRAM, good luck...
ORIGINAL: DyNaBoB
lol yea sorry had to do it
