Arlen Ness A/C studs broke off???
Old 10-22-2007, 05:09 AM
tannerwelch's Avatar
tannerwelch
tannerwelch is offline
Default Arlen Ness A/C studs broke off???
Any others have this happen. Had an Arlen Ness Big Sucker II A/C on for about 2,000 miles.On a ride this past Sunday A/C falls off while riding. All three studs broke off at fuel-injector body.Luckly the A/C hit my leg and I was able to grab it before it hit the ground. Just wanting to know if any others have had this happen? Thanks,Tom(2006 lowrider)
Old 10-22-2007, 11:06 AM
murphdog's Avatar
murphdog
murphdog is offline
Default RE: Arlen Ness A/C studs broke off???
My back plate broke where the studs go through it, but never heard of the studs themselves breaking. The back plate is pretty fragile and it's common to hear about them breaking. Ness really needs to find somewhere other than China to have those things made. Mine was a POS and the warranty replacementwas no better. I have a Screamin' Eagle air cleaner now.
Old 10-22-2007, 12:14 PM
abcd9906's Avatar
abcd9906
abcd9906 is offline
I have had it happen to me also. My studs broke off and I caught my air cleaner before it fell. The other time my a/c plate that you screw the allen heads into ... the holes cracked out and I about lost it again. Cheapo quality man. Never again will I buy some arlen ness shlt
Old 10-22-2007, 02:36 PM
lost6009's Avatar
lost6009
lost6009 is offline
I had two arlen ness mirrors break off at the weld on the ball that goes into the stem. One fell in my lap and the other hit the street. Luckily niether hit the bike oddly enough. I haven't bought ness stuff since.
Old 10-22-2007, 02:43 PM
Sec Super Glide's Avatar
Sec Super Glide
Sec Super Glide is offline
Thanks for the heads up on that air cleaner I bet alot of us are useing them >[sm=badidea.gif]
Old 10-22-2007, 04:30 PM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
Gee,
Now I don't feel so bad for buying genuine HD stuff from time-to-time.
I have rarely had problems with HD stuff (China or not), and when I did my local HD parts guys never gave me a hassle returning stuff.
Thanks for the heads up on Nessy!!
DougJ
Old 11-28-2007, 01:26 PM
hywy2hl's Avatar
hywy2hl
hywy2hl is offline
Lovely! I had this happen too; one screw/bolt holding the stud in place broke off, so I guess I can try to drill the screw out and replace the screw. Does anyone know if Arlen Ness will replace it or give replacement parts?
Old 11-28-2007, 02:27 PM
fiend138's Avatar
fiend138
fiend138 is offline
ORIGINAL: hywy2hl
If not this site http://www.mcmaster.com/has a great online catalog of hardware.
Old 11-28-2007, 03:19 PM
2007fxdc's Avatar
2007fxdc
2007fxdc is offline
Just curious how many of you torqued the bolts to spec when you installed the kit? I didn't, so I'm not preaching to you - I didn't own a torque wrench at the time. I wondering if it will help prevent it if I pull the kit off and reinstall using torque specs?
I also wonder if the kit was even developed with the extra vibration of dyna's and non-softails in mind? Kind of makes me wonder if they developed it around a softail and the vibrations from our motors are causing the hardware to fail. I wonder if Arlen Ness (the company not the person) knows about this and would be willing to do a sort of recall fix?
Old 11-28-2007, 04:56 PM
ColoSpgsMark's Avatar
ColoSpgsMark
ColoSpgsMark is offline
I know that when I purchased this HD cover http://www.harley-davidson.com/gma/g...bmLocale=en_USto go over my Big Sucker, it advised to replaced the one piece studs with new HD two-piece ones (29447-99A). The one-piece studsto replace look just like the ones AN uses, but they are a hair longer. So, I'm guessing its a somewhat known issue that the one-piece studs don't hold up.
Mark
Quick Reply: Arlen Ness A/C studs broke off???
