Switching to mini apes
RE: Switching to mini apes
I changed mine to mini apes , the ones the wide glide has and i had to change the brake and the clutch cable. oh and had to pull some of the excess wire out from under the tank and reroute my throttle cables behind the forks.... the biggest thing for me was changing the clutch cable.. not to much of a big deal tho.... hope this helps...
kman42oo
kman42oo
What he said. Now's a good time to upgrade to stainless brake line. Although you could probably find some stock WG take offs on e-bay.
Be carefull about ordering the right parts. Stock '05 WG bars are 1", and cost about $50. '06 bars are 1 1/4" and cost about $200. The larger HD bars won't fit unless you change your bar clamp, speedo housing, grips, and hand controls.
Personally, I like the aftermarket 1 1/4" bars. They're heavier and vibrate less. Although the specs are the same, their shape is a little bit differant, and the hand grip area is more ergonomic that HD's bars; much more confortable on a long ride. You don't have to upgrade the clamps or grips. But they are still almost $200.
My plan is to add the stock '05 WG bars for $50. Ride them around for a while. If I like them, I'll spring for the better aftermarket bars. If not, I'll choose something else. It's easier to deal with lines that are 2" too long, than 2" too short.
i changed my 05 superglide to mini apes i went ahead and changed all the cables the only trouble was getting the front brake cable but i did get it and it sets the bike off real nice i dont have any pic. yet but i thing you will like it .best of luck [sm=biker.gif][sm=goodidea.gif]
