intalling foward controls
RE: intalling foward controls
ORIGINAL: hubcap
Is it very difficult to install forward controls? I dont have a bike yet, but leaning toward the Dyna Bob. Definately need the foward controls
Kuryakyn makes some controls for your dyna that are very easy to install and do not require any work be done to the primary. Instead the mid-shift components are hidden away allowing you to switch back to mids very easily later on should you decide to use them or sell your bike to someone that prefers them.
I don't think the HD kit comes with a beauty cap for the old spline. I think you can find one that will work. HD wants you to remove the primary cover and then the mid shifter parts, plugthe holefrom the back and put it all back together. If you choose to just use a cover, don't forget you have to do something with the mid-shift linkage sticking up out of the back of the primary - you don't want that just wondering around back there. The Kury kit comes with a clip to bolt to it to lock it back out of the way and hold it there. You probably won't be able to find something like that lying around a dealer's store by itself.
ORIGINAL: 2007fxdc
