Baffles on stock pipes.. ??
So, I was told by the guy at the dealership where I bought ny bike from that I could actually remove the baffles from the stock pipes and be ok. Is this true?
I know on the bike I had (07' vulcan 900 custom) I was able to remove the baffles from the stock pipes and the bike would run just fine without any proplems, but is it the same with this?
I can't really afford the pipes I want right now, and can't stand the quietness of my stock pipes, so are there any other options??
Thanks in advance!
Cheers,
Adrian
Thanks in advance!
Cheers,
Adrian
RE: Baffles on stock pipes.. ??
You can do it but it isn't real easy. You will need a hole saw, dremel, and patience.
Don't just knock a big hole in the blocking baffle. You just make small, quiet, straight pipes and kill low end.
I've got a post about it in exhaust forum.
https://www.hdforums.com/m_2273672/tm.htm
I did it to mine. It wasn't that hard. Just cut through the welds with a hole saw, and then knock them out with a long rod and a hammer.
Here's a thread I made about awhile back:
https://www.hdforums.com/m_1669771/tm.htm
LowBoy08
04-08-2009 01:07 AM
Clinton350
10-19-2008 07:41 PM
