Removing front exhaust bracket
Old 10-07-2007 | 01:28 PM
cornishman's Avatar
cornishman
Default Removing front exhaust bracket
Apologies if this tip has been previouly covered. Read backalong about the difficulty removing the front stock exhaust clamp plate. (the one thats screwed into the bottom of the engine above the frame). The problem being that 2 of the 3 torx screws are difficult to access because the frame gets it the way. I got over the problem by grinding flats onto the torx bit so that i could turn it with an open ended spanner (i used a 13mm). I used a flat wallpaper scrapeto apply upward pressure between the frame and the torx bit. After loosening the screws i turned them out with pliers/molegrips.It certainly looks better without the bracket with the V&H Shortshots. Hope this helps. LOL
Old 10-07-2007 | 03:30 PM
Black Bart's Avatar
Black Bart
Default RE: Removing front exhaust bracket
Thanks for the tip Cornishman. Now I know how I can remove mine.
Bart
[IMG]local://upfiles/16365/9D42417680D2489EB42804809EDA5A93.jpg[/IMG]
[IMG]local://upfiles/16365/6CAFE24C53BB4B0683EBAB8CB65AD049.jpg[/IMG]
99%r
01-05-2014 11:21 PM
brown dawg
04-12-2012 11:59 PM
brenn
03-25-2012 04:36 PM
wasp
03-18-2007 05:51 AM
Quick Reply: Removing front exhaust bracket
