Forward Controls Question
Im going to fit a set of forwards to my FXDX, Im aware that this will leave a hole in the primary side where the shifter goes through, will there also be a hole at the back of the primary also? Whats the best way to block these holes? Are they under pressure or will a couple of black bungs do it? I could always get another inspection cover with no hole presumabley?
Received 4,770 Likes
RE: Forward Controls Question
the outer primary is the easy fix, buy the small primary inspection cover and gasket to replace your cover that has the hole in it. get one from the wideglide model, they already have fwd. controls. the shaft will have to be cut so that it can be removed from the inner primary cover. may want to cut it between the inner pri. cover and engine. a long process with a piece of hacksaw blade. install plug from inside out with silicone sealant. maybe while you are in the primary consider installing a M6 chain adjuster. it's a pretty neat and functional add on. good luck. (this is for the 99-05 models)
ORIGINAL: Malc_F
If it's that easy, I'm glad! It looks like you have a chrome/silver plug fitted?
If the holes are left does the trans oil actually come out? Or is it a sealed gallery/tube that the shifter rod passes through?
Thanks for all replies, it has been helpfull!
I can see now that the work to the primary is cosmetic, and to be honest thats what I was concerned about, leaking trans fluid! But since that is not the case I'm going ahead and get the forwards, it's going to be a lot more comfortable, my 1200S was fitted with forwards and I have missed them!
The one thing that I can see that's going to be a pain the **** is doing oil changes. It looks like I'll have to remove the shifter to get to the oil filter. But, oh well, it's worth it.
Bart
[IMG]local://upfiles/16365/638FAC00BEF74EF4A3F6F3B083A31ABC.jpg[/IMG]
[IMG]local://upfiles/16365/067F512B6A2E4C22B695B6BBC0D8E832.jpg[/IMG]
[IMG]local://upfiles/16365/60C80FC8A21E475FBC942FC34BDF1F3B.jpg[/IMG]
Bart
