any detachable saddlebags with detach sissy bar withou relocating turn signals?
If you get our smaller shock cut out bags, there shouldn't be any problem. It's just whether you want small or big bags. Obviously the bigger ones would require turn signal relocation...
You have to keep in mind that it'll be a really tight fit. We don't recommend it because it doesn't give too much room for error. About 1", the bags will bounce and travel that much sometimes during regular commuting on bumpy roads.
Check out what we have to offer, http://www.vikingbags.com/harley-dav...saddlebags.htm
This is another dyna owner who relocated his signals, but you can get an idea.. of size of the bags.
bags, bobtail, bracket, cruiseliner, fender, glide, hd, relocating, saddle, saddlebags, signal, signals, turn, vrod, wide
