Rear Primary Bearing Question
Old 09-24-2007, 06:03 AM
Sammi's Avatar
Sammi
Sammi is offline
Default Rear Primary Bearing Question
'06 Low Rider had 5,500 miles and I thing I'm hearing "funny noises".
What are the symptoms of a badrear primary bearing?
Dealer can't get the bike infor a few days.
Thanks,
Sammi
Old 09-24-2007, 07:52 AM
Tnbrit's Avatar
Tnbrit
Tnbrit is offline
Default RE: Inner Primay Bearing Question
Hi,Sammi.I'm definatley not an expert,but my 07/FXD,has a noise which seems to be coming from the primary drive area,which my dealer tells me is the "Compensator",I think it may be an auto tensioner(not Sure),But they can't seem to make it stop after 3 attempts,it's probably a figment of my imagination(like all the 6 speed issues)but the noise is still there.
Cheers,Graham.
Old 09-24-2007, 07:58 AM
cadman311's Avatar
cadman311
cadman311 is offline
15,000 of The 06 lowrider were recalled for the bearing ask the dealer if your number is on the recall lists.
Old 09-24-2007, 08:05 AM
Sammi's Avatar
Sammi
Sammi is offline
ORIGINAL: cadman311
Will do.
Thnaks,
Sammi
Old 09-24-2007, 08:57 AM
mud's Avatar
mud
mud is offline
muderator
Received 9,109 Likes on 2,119 Posts
ORIGINAL: cadman311
Out of curiousity,
where did you get this info
that 15,000 LRs were recalled.
mud
Old 09-24-2007, 09:25 AM
06dynablack's Avatar
06dynablack
06dynablack is offline
I never heard bout 15000 bikes being recalled for the bearing either.Knock on wood justy shy of 30k miles on bike no weird noises from primary
Old 09-24-2007, 09:31 AM
crpdstr's Avatar
crpdstr
crpdstr is offline
Stage IV
Hi Sammi,
I just had my primary inner shaft bearings replaced at 10,700 mi on my 2006 fxdi. The sound is unmistakable. When I first started it and cold there was no noise, then after putting it in gear and even going around the block and coming to a stop there was no noise. Leave the engine running and put transmission in neutral and let the clutch out, you will hear grinding noise or rubbing noise. It gradually gets louder as you ride it more. I finally decided I had a problem when you could hear that noise while riding down the road.
crpdstr
Old 09-24-2007, 09:36 AM
Sammi's Avatar
Sammi
Sammi is offline
ORIGINAL: crpdstr
Hi Sammi,
crpdstr
Pretty much sounds like what mine does.
Off to dealer as soon as they can fit me in.
Did it take the dealer long to fix once they got the parts?
Sammi
Old 09-24-2007, 09:42 AM
crpdstr's Avatar
crpdstr
crpdstr is offline
Stage IV
Took it in on Tuesday morning and got it Thursday morning.
Crpdstr
ponte's Avatar
ponte
ponte is offline
crpdstr already described it pretty well. I had no noticable noise when in gear but put it in neutral and let the clutch out and it was loud as hell. I had the misfortune of having my bike at the dealership when everyone else did in the middle of July. Took me three weeks to get it back and that was after calling the owner. Hope you have better luck.
Quick Reply: Rear Primary Bearing Question
