cvo injectors
Old 09-19-2007 | 08:12 PM
snooper0069's Avatar
snooper0069
Default cvo injectors
I did a search on the stage 1 download and saw were a tech posted a response saying install cvo injectos and there would be no need for pc111 , sert, or any other download. anyone heard of this
Old 09-19-2007 | 10:02 PM
darkdyna06's Avatar
darkdyna06
Default RE: cvo injectors
I think the 25 degree injectors installed on all 06 1/2 and later bikes are the same as the CVO parts.
Old 09-19-2007 | 10:41 PM
shoptroll's Avatar
shoptroll
Even if the CVO injectors are larger and allow more fuel the O2 sensors would register that and the ECM would adjust to maintain the factory AFR of 14.7 / 1
Old 09-20-2007 | 11:50 AM
man4mopar's Avatar
man4mopar
ORIGINAL: shoptroll
It wouldn't in the open loop sections.
But that is beside the point. Higher flowing injectors would richen the open loop sections but unless checked you do not know the AFR in that area. Nor do you have any way of tuning it without a SERT, PCIII, Tmax or any other system out there.
jeff53404
2014-2023 Touring Models
11-04-2016 08:15 AM
KBFXDLI
03-04-2008 09:39 PM
chopperchuck
03-10-2006 11:18 PM
DWB4L
03-05-2006 05:22 PM
doomie19
03-03-2006 01:23 PM
Quick Reply: cvo injectors
