Do it yourself download
RE: Do it yourself download
If you are talking about changing the map and if it's a PC III USB, after installing the program in the laptop and downloading the map from powercommander.com ( http://www.powercommander.com/powerc...b/default.aspx), the right one for your bike and setup, it takes a couple of minutes; start the bike, the PC III stablishes communication with the pc, you open the map you want to install and press "Send MAP", you get an Ok and you stop the engine before you asfixiate in your garage....
If you are not talking about that...I haven't a clue..
