Warning!! Really Stupid Question! Tire Pressure!
Old 09-12-2007 | 09:15 AM
pauletich's Avatar
pauletich
Default RE: Warning!! Really Stupid Question! Tire Pressure!
I run 32 in front and 38 in rear. For your size you may want to go 33 in front and 40 in rear.
Old 09-12-2007 | 09:32 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: Twincam Dave
Please explain how it will shorten tire life, this I gotta hear.
Because the number on the side of a tire is typically max pressure and doesn't correspond with recommended pressure for your vehicle, inflating your tires to that pressure is essentially over-inflation and the tires wear as such.
Old 09-12-2007 | 08:51 PM
06dynablack's Avatar
06dynablack
ORIGINAL: 2007fxdc
bullhockey
Old 09-13-2007 | 12:08 AM
DougsDyna's Avatar
DougsDyna
ORIGINAL: docsg
ORIGINAL: mudpuddle
ORIGINAL: 07bobber
the psi is on the tires.
i run 42 in the rear for two up
andabout 38 in front
Don't know about the front, but I would run at least 44 lbs in the rear. Metz's like much more air. I think max on the Metz rear is 50 psi.
DougJ
38 is too much in the front.
mud
I have the Metzler 880's and I've been running 40 front/rear. Should I decrease the front?
Old 09-14-2007 | 05:08 AM
jimw411's Avatar
jimw411
I'm 6'3" 300lbs and i run 31 in the front, and 36 in the back, 40 in the back with a passenger. I have my shocks set on #2 and i never bottom out. I carry a wrench to kick up the shocks when i put on a passenger, and if i'm going further them across town i air up the back.
Old 09-14-2007 | 05:16 AM
Ben Riden's Avatar
Ben Riden
I find that about 10% under what the tire manufactor recommends as max pressure works well on my bikes.
Bob
Old 09-14-2007 | 05:32 AM
Chief40al's Avatar
Chief40al
There is a sticker on the front bar of my frame that has the PSI for my bike for solo rider. I dont recall the # right now.
Old 04-16-2017 | 07:32 PM
Hoppergrass's Avatar
Hoppergrass
I'm guessing, who would know more about the tires? HD (the manual), or the tire maker? I'd have to go with what I see on the tire. I have an '06 Dyna Low Rider. I'm sure the tires have gotten better since then. I have a Dunlop D401 up front, and psi reads 41 cold. When I first got the bike last December '16, I tried the manual at 32 psi. When I would brake normal, front tire felt like a marshmallow, and unstable. Even the tire tread is loudly heard like it was a flat tire. So I picked a middle point of 38psi, and it feels, and corners well.
Old 04-16-2017 | 08:36 PM
Ghost_13's Avatar
Ghost_13
Resurrect a 10 yo thread to talk air pressure..., and a tire no one uses
up your game my man
Ghost
Old 04-17-2017 | 05:20 AM
Mchad's Avatar
Mchad
up your game my man
Ghost
There's got to be a prize for this....
Quick Reply: Warning!! Really Stupid Question! Tire Pressure!
