Loaded the map last night and what a difference! No popping or backfiring on decel, 6th gear indicator is working again, AND its running a lot better than any of the other maps I've tried.
where did you get the map? what kind of bike do you have... should i have a 6th gear ind. on my 06 bob as well? I have a stage 1 SEII slip ons, and the power tuner in her
Just uploaded the new map, I find it's running about the same for me as the last map. Maybe a little stronger in the mid range, but not much. I didn't have much decel popping before either. We'll give it a few miles and see what I think then. Thanks Drexor!
Once you're in Smart Link click on "EFI Maps", the first screen you'll see is probably the screen that shows all of the maps for you to select from. Close that window and click on "Update Definition File" which will go online and search Zippers database for maps. Once that is done go through the normal process of selecting your map, the new maps are 403 and 404.
You'll need to go through the whole initialization processess again...
And yes, I believe your SB should have a 6th gear indicator light but I'm not sure since mine is a WG.
You don't need to go to a web site, Smartlink will check Zippers servers automatically. You just need to make sure that the PC you're running Smartlink on has access to the internet.
