Blowing Headlight Bulbs
Not really a question, but rather a frustration.
I have an '06 FXDWGI and it has started blowing headlight bulbs like crazy. HD repalced the headlight bucket about a month ago, but I'm not sure when how long it has been out as I haven't been out at night in awhile. (Got caught in the dark last week) They replaced the bucket bucause the rivets were loose causing it to rattle.
I replaced the bulb and it burnt out the same day. So I turned on the high beam to get home and it burnt out about 3 blocks later. I am on my 4th bulb now. I have put a volt meter to it and let it run in the driveway for about an hour ( in all RPM ranges) and am getting a max. output of 14.2 volts. Which is correct according to the mechanic at HD. There really isn't anything it the headlight bucket that would cause the bulbs to just go out.
I took it to the local HD to have them take a look at it. I was told by the mechanic that I had checked all the things they can check and that he can't think of what else would be causing it. WTF? So am I supposed to carry around a dozen bulbs and a screwdiver for the next time it happens?
Nothing else is burning out. Taillight, marker lights... If it were a spike from the regulator, other things would go out. It's not popping fuses, just the headlight.
So, they have it right now with the idea that I have checked everything...
RE: Blowing Headlight Bulbs
get a cheap bulb from the auto parts store and see if it happens. sometimes there are bad lots of bulbs that are prone to vibration failure.
it is doubtful that the bulb is burning out from voltage spike if the alternator, voltage regulator and battery are functioning as designed. only other thing that i can think of is making sure there are no fingerprints on the bulb when being installed or possible interference from the lamp hood located in the reflector assy.
UPDATE:
Well, the bike is back and they didn't do anything to it. They tried to get it to "Blow" and it never did.
All the bulbs (4) that have blown have come from different sources. I have been really careful not to touch the glass and make sure it isn't bumped replacing it.
So far, 175 miles since it has been in the shop and it has not blown this bulb. Not sure what the hell is going on, but I'll keep an eye on it.
