Idle, minimum permissible and why
I know that the older Harleys with a carb can idle lower than the injection models; my question is WHY?? and don't give any of that oil pump not pumping enough ASO. I guess it has to do with the injectors. Having a PC III I can adjust it lower (I think....), but let's see some grey matter here, C'mon brain, I know you are there....
RE: Idle, minimum permissible and why
Higher RPM to maintain correct voltage/amperage for ECM and Fuel pump(it's electric.LOL). The only way I've seen to lower idle speed correctly is with the use of SERT, can lower to your hearts content, not recommended though. Idle time is minimal during riding, why bother adjusting .
Stay Safe.
Stay Safe.
