fxdwg 1998
08-28-2024, 09:05 AM
fxdwg 1998
hi. why does the oil from the gearbox flow into the primaries? It doesn't leak or drip from the motorcycle anywhere.
08-28-2024, 09:29 AM
I have never heard of tranny oil migration in an EVO engine bike
When it happens on M8`s it`s due to trans oil traveling along the clutch throw out rod
Are you SURE it`s trans fluid ?
More common would be engine oil coming past the crankshaft seal
Provide more details please
08-28-2024, 10:09 AM
the oil is reduced in the transmission box. I'm draining it from the primaries. several times already.
08-28-2024, 10:42 AM
Quote:
Originally Posted by
Olegpeg
Oil doesn`t flow from a 5-speed gearbox to the primary, unless you store the bike laying down on its left side.
08-28-2024, 11:51 AM
in the parking lot, it stands on the left all the time.
08-28-2024, 02:16 PM
Olegpeg
Yes, but it does not lay on its side...
You need to set all the oils to the correct level and check them all after a few hundred miles to determine what the issue is.
08-28-2024, 04:58 PM
It stands like that all the time.
08-28-2024, 05:02 PM
1 litr primire
1 litr gearbo
4 litr engine
evolution 1998
08-28-2024, 05:06 PM
Are you checking this via the transmission dipstick? Please provide photo of it.
08-28-2024, 05:15 PM
I'm checking the transmission probe. It's decreasing all the time. and in the primary, the oil increases. maybe the probe is wrong?
