Heat Cycling Big Bore Install
Old 08-07-2024 | 04:14 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by override
​​​​​​Build up is probably the wrong word, more like deposits, my fault. Though yes, the top outer edge of the piston and the very small gap around the cylinder head gasket where they mate up with the cylinders. Not allowing that to build up can create small hot spots on the sides of the pistons. Also the beneficial deposits around your ring gaps that can help promote the rings sealing against the walls.
We definitely aren't talking about a lot of deposits, very little in fact.
I know it's not apples to apples but in the 2 stroke world it's called piston wash, if you ever pulled a head and didn't have carbon build up in the center of your piston it was a tall tell sign you are running too rich. When you are jetted properly a pattern will start to develop where the intake and exhaust ports are at. A really experienced mechanic or tuner can use that to know exactly what the carbs are doing if the motor is otherwise healthy.
Well, that's the first time I've ever heard (read?) it's necessary for head gaskets mating point.. Seems to me that it would cause hot spots and not stop them.. I thought carbon typically promoted hot spots..
On the motors I've disassembled, I've not seen buildup on the ring ends.. I have burned them with too much fuel and timing tho..
I would think that detergents in the gasoline would have more effect..
Been years since I messed with 2 smokes but I would think that lack of carbon buildup in the chamber would be due to too rich of a oil to fuel mixture and not AFR.
  #32
Old 09-30-2024 | 05:10 PM
snake_eyes's Avatar
snake_eyes
As a follow up, I've decided to take my bike out to FuelMoto and have them do the tune since I'm only about 4 hours away.
Reindeer (10-01-2024)
  #33
Old 10-01-2024 | 05:29 AM
eighteight's Avatar
eighteight
One wonders what the initial start up at the FACTORY entails ???
The following 2 users liked this post by eighteight:
Addicted to Chaos (10-04-2024), snake_eyes (10-01-2024)
  #34
Old 10-03-2024 | 06:10 AM
BlueridgeXL's Avatar
BlueridgeXL
On my last two builds, I used Hammers procedure and both motors run well and don’t use a drop of oil. Living on a massive hill helps with decel sealing.
One question I have is on the lifters. I’ didn’t install new lifters on either one of my builds. In my auto days we’d grab a primer spin the oil pump until we had flow out of the pushrods to the rockers and adjust. Is it worth the time to let them sit in oil, perhaps a sealed jug with a vacuum? Adjusting preload correctly before starting is the primary concern.
The start up of my build is a ways away, planning on spending some time watching Mr. Baxter and Hammer Dan to catch some insights.
  #35
Old 10-04-2024 | 01:39 PM
Cleverusername's Avatar
Cleverusername
someone correct me but ideally wouldn’t we want our combustion chamber to be free of oil? I understand cylinders get oiled but the rings scrape off on down stroke. Am I wrong? Also wouldn’t the detergents be a benefit in a well maintained oil system? I know you are talking two stroke but in a four stroke I could see deposits becoming hot spots that would/could cause detonation (pre-ignition) issues.
  #36
Old 10-07-2024 | 06:41 PM
Spanners39's Avatar
Spanners39
Never been that fussy with heat cycles, never had an issue. Our race bikes never got run in at all, usually there wasn't time.
John CC (10-07-2024)
  #37
Old 10-07-2024 | 11:16 PM
Rounders's Avatar
Rounders
You have more experience, and maybe right. But if you are constantly rebuilding, do you care about burning a little oil?
Breaking in engines, is an age old debate. For me, I don't think it hurts to heat cycle. I am not racing and in no rush. Maybe it doesn't do any good.
  #38
Old 10-08-2024 | 11:46 PM
Spanners39's Avatar
Spanners39
There are some that say do not heat cycle at all, the instructions that say use a stopwatch and do 10-second, 20-second etc heat cycles seems just a very good way of avoiding owner-installed warranty claims as nobody will do it that way and they can say you didn't follow the instructions to the second and so "sorry, out of warranty parameters at install".
That would be my professional opinion and possibly that of many other professional wrenches. I can guarantee you that brand new Harleys are not heat cycled like that in the factory and never have been.
The following 3 users liked this post by Spanners39:
eighteight (10-09-2024), Max Headflow (10-08-2024), snake_eyes (10-09-2024)
  #39
Old 10-09-2024 | 05:56 AM
Schex's Avatar
Schex
If you're reusing lifters, disassemble and clean them, they will have black oil in the bottoms of them, you could also flip the plate over to get a new sealing surface. (I usually disassemble, clean and inspect new lifters)
Use a few drops of oil to assemble them, but leave then empty.
Before you install the top rocker covers is a good time to adjust pushrods and prime the oil system.
It's easy to see where zero lash is and no wait for bleed down after adjustment with empty lifters.
Then prime the oil system, spin the engine with the plugs out until you see oil coming out the rockers, and make sure the oil gets to the valve stems.
Don't kill the starter, you may have to let it cool a time or two before all rockers have oil coming out.
You should have previously removed shafts and clean the inside of rockers and make sure oil holes are clean.
Finish engine assembly, it's ready tp go.
BlueridgeXL (10-10-2024)
  #40
Old 10-09-2024 | 07:47 AM
Rounders's Avatar
Rounders
People building engines in their garage are not warrantied about warranty. They are not warranting engines you put together. Everyone has their own theory, but warranty is not thought of .
As far as assembly, coat with oil, dry metal and metal is bad. As said pull plugs and turn over.
