8 degree injectors (I know, AGAIN)
With 11,000 miles, I've only now started to experience the 8 degree injector issue. Ihad earlier assumed that since I didn't have the symptoms at the time of the service bulletin (Feb 06) that I would not be affected. I have a service appointment to "check it out". Has anyone else had no problem until they put some miles on like I did? Up until this month it ran great, now, without any other changes, I'm getting the cold starting and surging problems.
RE: 8 degree injectors (I know, AGAIN)
Still got my 8 degree injectors. I had an intermittant misfire that got worse until it threw up a code as 'Rear injector open / low'.
Got the meter on it and found that the power feed wire to the injector had broken (inside the insulation) and the signal wire had 2 or 3 strands left. (There is not enough of a service loop out of the harness to allowengine movement.) Pieced them out and everything running well again.
Not sure if it makes a difference but we have 95 to 97 octanefuel in the UK.
M-1185 Fuel Injector/Calibration Changes For 2006 1450cc Big Twins
February 20, 2006
Purpose
It has recently been determined that the 8° angle cone spray fuel injectors used on 2006 1450cc Big Twins may cause cold start and/or driveability problems on some motorcycles.
In the interest of promoting customer satisfaction, the 25° angle cone spray fuel injectors used on CVO 103 cu. in. (1690cc) motors will be installed on all production Big Twins beginning on or around February 13, 2006.
Additionally, Harley-Davidson will provide for the installation of 25° angle cone spray fuel injectors on those motorcycles where use of the 8° fuel injectors (part number 27625-06) is determined to be directly responsible for cold start and/or driveability problems.
NOTE
Due to changes in the manufacturing process, the part number of the 25° angle cone spray fuel injector is changing from 27709-06 to 27709-06A. This fuel injector also will be stamped with the words “25 DEG” for easy identification.
February 20, 2006
Purpose
NOTE
