softail wheel on dyna
[hello mate. Got some part numbers for you. this is for a 07 super with wide tire kit already installed.
part number 41228-07 HD HDP WHEEL, RR/HOLE/BLK 17X6' $381.99US (softail wheel)
part number 43861-08 HD HDA WHEEL, INSTALL KIT 1' AXLE $69.99 US
I orderedthroughmy HD partguy. He said they would work. ]
Try this
Daz
Try this
Daz
Got the wheel and hub kit, the hub kit comes with two different size spacers. I do not know if eather of these spacers will work on need modifing.These are HD stock parts/components. I still have some good tread remaining on my currenttire and will have the convertion completed once tire needs replacing.To play it safe I will installanother metz 190/50 which I am currently running on the07 stockwheel which measures 5.5", onto the 6' stock nightrain/softail wheel. The .5 or 1/2" difference in wheel width willallow the190mm tire( which recommeds 6" wheel ) to fill out and runas designed and not domed as on the 5.5 wheel. There are a number of good tire optionsfor a 17x6" wheel.
I decided to have my compensator replaced with a 30 tooth direct drive sprocket and a IDS (modified to work) installed and some other stuff done, in addtion to the wheel. I aploogize to those inquiring minds wanting to see the converstion. The person doing the work for meworks for a dealership andtakes on addtional work in his spare time on the side. I am very confident thatall should be completed before to long andlooking forward with great anticipation.
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
