Can't get it firm, is it too big or too small?
Old 12-19-2023, 01:53 PM
NEWROADSTER's Avatar
NEWROADSTER
NEWROADSTER is offline
I have plenty of towels around on the bike when I do this. I also hold a rag around the line fitting and leave enough visible for me to see bubbles. If you go slowly the mess is not as bad as you think. The last time I did it, I made no mess bleeding, but the bike was on the jack. When I put the rags down the damn handlebar turned because I was not holding it, Fluid spashed everywhere because the lid was not on the master cylinder.
I learned to tie the wheel straight ahead!
snake_eyes (12-20-2023)
Old 12-19-2023, 02:12 PM
snake_eyes's Avatar
snake_eyes
snake_eyes is offline
Received 1,249 Likes on 733 Posts
Originally Posted by Uncle 'B'
What size are the stock pistons?
Also, if you hold them face-to-face, do the new pads have about the same surface area as the stock ones?
I'm all in for giving Brembo a call. This ain't their first rodeo so they may have the info you need to ensure that you have the correct master-to-slave ratio before you proceed down other avenues.
I don't know the stock size; I was going to look it up but got really busy. I did reach out via chat to Brembo USA, we'll see what they say.
Uncle 'B' (12-19-2023)
Old 12-19-2023, 04:18 PM
snake_eyes's Avatar
snake_eyes
Well, Brembo told me, politely, to contact SpeedKings who I purchased from. I get it, but still, seems kind of shitty. I mean it really is a math question, what size bore master is optimal to drive my 8 x 30mm piston setup? I know it's not exactly that simple, but I'm not tracking the bike so there's room to fudge...would I be wasting my time getting a 15mm because it'd still be too small?
Old 12-19-2023, 07:07 PM
union53's Avatar
union53
union53 is offline
15mm is probably too small. Just a fyi, I'm not suggesting which way to go. I know you want to keep the stock look. When I upgraded my brakes I first went with a single disc setup. I used a caliper off a R6. I believe the piston sizes are 27/30. I use a Brembo 15rcs with it. When I went to dual disc I moved to the 19rcs. It's a very firm lever. I read somewhere the R6 uses a 16mm radial caliper with them but I don't know for sure.
Old 12-19-2023, 08:45 PM
John CC's Avatar
John CC
John CC is offline
Didn't you say you were already at 11/16"? That's a little more than 17mm.
When you go too big the usual problem is you loose feel because the brake goes from released to fully applied with a very small lever movement. It is often described as a "wooden" feel. It sounds to me like your problem is the opposite.
Old 12-19-2023, 09:07 PM
John CC's Avatar
John CC
John CC is offline
The 11/16" master will move about 1.5 times as much fluid as the 9/16" master. Assuming the two calipers you have now each need the same amount of fluid as the one you replaced, a 19mm master would be about right. 3/4" is about 19mm.
I recall someone posted a link to a site or two with calculations for this very problem. Not sure if it was here or somewhere else.
Old 12-20-2023, 07:56 AM
snake_eyes's Avatar
snake_eyes
Great info, thanks! I do remember now that someone had posted here about the 19rcs with their dual Brembo's. I did some more searching it is the recommended master for dual radial Brembo's. What I read though referred to the travel as being 19mm and not the bore, seems like I may have been misspeaking? I see that Brembo does make a matching clutch perch and lever so maybe a switch might be in my future.
Doh!
I have a link to the chart in my first post, is that what you're thinking of?
Old 12-20-2023, 08:19 AM
John CC's Avatar
John CC
John CC is offline
Yeah, that's one of them.
I just re-read your first post. 8x30mm pistons means you have to think really big! Do you know what the setup was that you last felt was good?
Old 12-20-2023, 08:27 AM
snake_eyes's Avatar
snake_eyes
Stock single front caliper with 9/16" master after I switched to braided line was the perfect feel for me.
Old 12-20-2023, 08:43 AM
John CC's Avatar
John CC
John CC is offline
Do you know what the piston config of the stock front caliper was?
Quick Reply: Can't get it firm, is it too big or too small?
