Brembo Spacing
Old 11-26-2023, 02:35 PM
Blowby's Avatar
Blowby
Blowby is online now
Just put a spacer on the top side of the bolt.
Old 11-26-2023, 02:46 PM
Blowby's Avatar
Blowby
Adjust the calipers out a bit more. I can’t see the inside area in your picture. Try to cover the original swept area.
1st picture is a closeup of the outside diameter of the disk and pad relationship.
2nd picture is the inside.
I will cut my bolts down next time the calipers come off. Just need 2mm trimmed off to make it look good.
Attached Thumbnails Brembo Spacing-img_2366.jpeg   Brembo Spacing-img_2368.jpeg
Old 11-27-2023, 10:39 AM
snake_eyes's Avatar
snake_eyes
snake_eyes is offline
Received 1,168 Likes on 692 Posts
Thanks for that info. I was going to run a spacer up top but the only ones I have on hand have an OD that's too large for the area. Right now, I have the outside of the pad just a hair further inside the swept area on the rotor than your pic. With the 2.5mm spacers I have I can either leave it where it's at or it'll be flush with the rotor edge so I'm going to order solid spacers that are 8.5 or 9mm to get the placement just right. I was going to cut the bolts down but came across these guys ARP (allensfasteners.com) single bolts for ~$5 and I'm waiting for new brake lines from Galfer so I've got time...phhhttt, like I can ride before May anyhow!
Old 11-27-2023, 11:51 AM
brownie4412's Avatar
brownie4412
brownie4412 is offline
Received 1,030 Likes on 599 Posts
I wish I would have known you were getting new lines. I have a set of stock length stainless lines from Galfer from before I went +2"
snake_eyes (11-27-2023)
Old 11-27-2023, 12:49 PM
snake_eyes's Avatar
snake_eyes
Hey, I appreciate the thought, but they were already +2 Galfer lines but just too short with the new radial setup. I figured it was a good chance to get the banjo angle right since the 90 degree wouldn't have been right anymore.
Old 11-27-2023, 01:01 PM
brownie4412
Ahhh yes. I knew that. Whoops!
Old 11-27-2023, 02:23 PM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Received 1,013 Likes on 602 Posts
I hope your not planning on using ARP black oxide bolts. They Will rust. I have been in the trade for over 45 yrs.
Old 11-27-2023, 02:45 PM
snake_eyes's Avatar
snake_eyes
Nope, my bike is mostly black with some tasteful chrome/SS here and there. All my ARP's are SS.
Old 11-27-2023, 03:03 PM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Excellent!
Old 11-28-2023, 07:19 PM
Blowby's Avatar
Blowby
After all this talk I went out and cut my bolts down 1/8". See what you did here...
Quick Reply: Brembo Spacing
