Lubricant Drain Plug O-Rings: Part Numbers - 2007 Dyna FXDC Super Glide Custom
Hello,
Are the drain plug O-Rings the same part number for all three of the drain plugs for the engine oil, transmission oil and primary chaincase oil? (ie. H-D part number: 11105)
RE: Lubricant Drain Plug O-Rings: Part Numbers - 2007 Dyna FXDC Super Glide Custom
Hello - Lowe's ?? I'm not familiar with that source (you're not talking about Lowe's the hardware store are you?) Do you have a part number for these O-rings?
Yes, Lowe's has o-rings, should be able to find a suitable o-ring at any hardware store. The correct size is #41 9/16" OD x 7/16" ID. Fits all three drain plugs and also inside the quick disconnect on the fuel tank.
The 11105 doesn't fit the chaincase on my '04 Wg - the chaincase takes an 11324 and motor and tranny take 11105's. Are the o-ring's at Lowes oil resistent, heat resistent etc - will they hold up OK? I have been thinking about looking for replacements other than at the stealer because I know .45 and 1.75 is waaaaay too much to pay for a friggin o-ring. Thanks in advance.
