Anyone got the Kury relocation kit?
I hate how far out the Harley turn signal relocation kit sticks out on my 07 FXDC & went to my Harley dealer today to find out some possible alternatives for something "shorter". They told me that Kuryakyn sells a mounting kit for $24.99 that'll make them look alot shorter? Part # is 2390...here's a pic below. Anyone have this same kit on their bike? Pics? Like/dislike?
RE: Anyone got the Kury relocation kit?
I take it you haven't purchased the kit yet?
You and I have the same bike. I let the parts guy talk me into rigid sideplates on mine because of this exact issue - the signals look strange, especially when the sissy bar is removed. However, I'm really considering changing my sideplates out for detachables. So, if you could post a pic or two of how yours look now and/or after you install the Kuryakyns, I'd like to see it.
I've got the Kury 49mm mounts,think they were about fifty bucks though. You'll also need a quarter inch chrome spacer to stand the factory bullett out from the mount,they won't fit flush,and also a correctly threaded button head bolt to replace the one that comes with the mount. Like the look a lot better than the factory kit.
Older pic showing sig at top of fork tubes.
Good Luck
Tom
Good Luck
Tom
No,those are the factory lights,all I did was buy the 49 mm clamp from Kury. I'm not familiar with the kit displayed in the first post.
I saw a bike the other day that had a small piece of bright metal with two holes about threequarters apart. The pinch bolt went thru the front hole and the turn sig was bolted to the back hole. Looked simple,clean and inexpensive,could be fashioned from a piece of flat alum from home depot and polished.
Good Luck
Tom
Good Luck
Tom
Tom,
I really like that set-up on your bike! OK, so I found the 49 mm fork mount clipson Kury's website, but where do I get the spacer & correctly threaded bolts from? Keep in mind I have an 07 FXDC, so please let me know exactly what I need.
Check out the new thread I started on this topic...you can post your reply there instead of here if you want?...
Ian
Ian
patsfan05488
07-03-2010 07:18 PM
