Fxdx pulley bolts snapped
Old 07-02-2023, 02:34 PM
NYCFXDX13's Avatar
NYCFXDX13
NYCFXDX13 is offline
Default Fxdx pulley bolts snapped
Hello iam new to the site. I read a lot of post about this issue today but wanted to ask if anyone has found a solution. Yesterday I was riding and all 5 pulley bolts backed out and snapped. Luckily I heard it and was able to get off onto the shoulder. The bike locked up after getting off highway. Theirs gotta be a solution to this problem!! Any help would be appreciated thank you in advance!
Old 07-02-2023, 02:42 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 9,403 Likes on 5,006 Posts
What year is the bike?
OEM wheel?
Did you install the bolts?
Old 07-02-2023, 02:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Deleted double post.
Old 07-02-2023, 02:52 PM
NYCFXDX13's Avatar
NYCFXDX13
OEM wheel?
2000 fxdx
OEM wheel
Harley dealer installed bolts
less than 700 miles on bike after install when this happened. And I had the plate guard on where it keeps the bolts from backing out.
Old 07-02-2023, 03:25 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,971 Likes on 4,163 Posts
New rim, and new proper grade bolts with the dry coat locking compound done to the correct torque.
Obliviously, the dealership didn't do it correctly.
Rarely do you ever see this unless someone has worked on it.
PS..
For sure..
Welcome Steve.
Hope you enjoy your ride here.
Only as a suggestion, create a signature
line for your
bike, year, model, and all the
code letters.
You can add that bike photo to the signature too.
And also as a suggestion, make your next new post over in the new member welcome area to say hello.
NYCFXDX13 (07-02-2023)
Old 07-02-2023, 03:27 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,864 Likes on 1,262 Posts
Originally Posted by NYCFXDX13
2000 fxdx
OEM wheel
Sounds like a visit to your dealer is in order. All five go at once WOW
Did they install the wheel or just the pulley?
Any other work done along with this?
WP
The following 2 users liked this post by WP50:
Goose_NC (07-03-2023), NYCFXDX13 (07-02-2023)
Old 07-02-2023, 03:32 PM
WP50's Avatar
WP50
WP50 is offline
The solution is most commonly found in the FSM.
There are variables to it but someone dropped one of the the ***** with this one.
WP
Old 07-02-2023, 03:48 PM
Rocking_it's Avatar
Rocking_it
Rocking_it is offline
Received 1,287 Likes on 446 Posts
How can you tell a new wheel is needed without pictures?
Old 07-02-2023, 03:50 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,986 Likes on 17,897 Posts
Get a couple pictures up and we'll be able to help you sort this out correctly.
WP50 (07-02-2023)
Old 07-02-2023, 04:02 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Because the bolts backed off and were sheared off.
The op has good reason to expect the wheel to be replaced.
Quick Reply: Fxdx pulley bolts snapped
