Fxdx pulley bolts snapped
#122
If the bolts go all the way through the hub, then there is enough elasticity in the bolt to maintain tension if the material should shift and relieve tension.. The problem is with shorter bolts, is that they stretch less elastically.. It's one of the reasons the threads are sunk in some increase the length of elastic part of the bolt.
Now going to a stiffer bolt, one that is less elastic, means the mating surfaces have to have less give so the tension is not lost.
Blue Bob is correct. Not enough material to dowel pin the pulley. A special bolt could be made that the slightest bit larger than the holes, make a special ream to size the hole perfectly. A lot of work and cost involved.
#123
Max Headflow (07-11-2023)
#124
Received 49,777 Likes
I'll beat the dead horse a bit more ... To the best of my knowledge this hasn't happened on a wheel that hasn't been serviced, correct? In other words the factory assembled assy works as it is supposed to ... This would lead me to believe that a whole bunch of people aren't doing something correctly, or using parts that aren't designed for the application
The following 7 users liked this post by Uncle Larry:
Blue Bob (07-11-2023),
Dan89FLSTC (07-18-2023),
M Oclaf (07-18-2023),
Max Headflow (07-11-2023),
Rusty Springs (07-11-2023),
and 2 others liked this post.
#125
#126
#127
#128
Blue Bob: Don't those sleeves also fit snugly into the bores on the wheel? Surely they provide some resistance to independent movement between the two.
(OT) "Stud and nut systems are also driven by the tapper." Do you mean taper? If not, I don't understand... Taper is one way of eliminating relative movement between two parts.
I agree that Uncle Larry is on to something. It's not just one thing, though. Clean surfaces, correct hardware, correct torque, and some sort of locking, maybe more. Mess up any one and you could be looking at a bunch of broken parts.
#129
Sleeves press fit with red Loctite.
#130
The following 2 users liked this post by 98hotrodfatboy:
Blue Bob (07-18-2023),
Uncle Larry (07-11-2023)
