Fxdx pulley bolts snapped
Old 07-10-2023, 04:30 PM
NYCFXDX13's Avatar
NYCFXDX13
NYCFXDX13 is offline
Originally Posted by joecha56
I have a stock swing arm you can have. In great condition
thanks for the offer I appreciate it. I already ordered one. Found it on eBay.
  #112
Old 07-11-2023, 07:16 AM
John CC's Avatar
John CC
John CC is online now
In all my years as an aircraft mechanic, I never once saw safety wire that was broken.​​​​​​
Exactly!
  #113
Old 07-11-2023, 07:27 AM
Andy from Sandy's Avatar
Andy from Sandy
Andy from Sandy is offline
Received 3,991 Likes on 2,548 Posts
Missed a few pages but for my 2017 bike HD call for new bolts and a two stage torque, 60 ft-lbs first go then 80 ft-lbs final.
My tyre fitter's machine couldn't take wheel with pulley so I had to remove it. Following the manual the pulley on my low powered Sportster has been fine.
Screws for my bike are 7/16"-14 x 1-3/4" Hex Head with Lockpatch - https://estore.chester-harley-davids...ch-p69328.html
  #114
Old 07-11-2023, 07:34 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,957 Likes on 4,033 Posts
Safety wire would not have helped except for the fact that the base plate is what caused the issue. Stock bolts and locktite would have been fine. Surfaces clean.
98hotrodfatboy (07-11-2023)
  #115
Old 07-11-2023, 08:05 AM
John CC's Avatar
John CC
At the risk of (re)stating the obvious...
If the bolts back out you loose tension between the pulley and the wheel, there is relative movement, and things go to hell in a hand basket.
If you lose tension between the pulley and the wheel, (e.g. powder coating, paint, etc.) then the bolts can back out. there is relative movement, and things go to hell in a hand basket.
There are enough reports of failures with all sorts of bolt locking schemes that lead me to believe it's not a simple as bolts backing out. I believe that absolutely clean mating surfaces and an effective locking scheme are both critical.
A few years back someone (Blue Bob, IIRC) proposed using sleeves to lock the pulley to the wheel. If you're a belt and suspenders and belt kind of guy, I think that's the way to go. Too bad it's not just bolt-on.
The following 2 users liked this post by John CC:
Blue Bob (07-11-2023), Max Headflow (07-11-2023)
  #116
Old 07-11-2023, 08:18 AM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Received 1,014 Likes on 603 Posts
Sleeves not to lock but to fill huge clearance in pully holes. Longer bolt shoulders to extend into the wheel counterbores to drive the wheel, and known good quality bolts. 70,000 psi + Safety wire.
There is several Harley bolts that are highly suspect to severely advance this problem.
Also I do not believe there is enough material to use bushings / sleeves to effectively lock the assembly together.
  #117
Old 07-11-2023, 08:39 AM
Andy from Sandy
On the wheel and pulley mating surfaces on my bike there is no coatings.
It is the same on my car as well. The mating surfaces are uncoated metal masked off before the paint went on.
Sleeves to stop the pulley from moving which is probably what causes the shearing of the bolts. A pin or two would have the same effect and keep the original bolts and holes.
  #118
Old 07-11-2023, 08:42 AM
Blue Bob's Avatar
Blue Bob
Blue Bob is offline
Auto wheel are driven with lug nuts.
  #119
Old 07-11-2023, 08:44 AM
Andy from Sandy
In the UK the wheels on BMWs are threaded holes in the hub and screws or bolts through the wheel. If they come loose it would be the same type of shearing action I think we are discussing here.
  #120
Old 07-11-2023, 09:23 AM
Max Headflow
While they can and some might. In this case they simply snapped off.
NorthWestern (07-11-2023)
Quick Reply: Fxdx pulley bolts snapped
