BELT TENSION
BELT TENSION
I get the feeling the belt on my final drive is far too tight, but since it is my first belt driven bike I have, I really don't know. The owners manual states 5/16-3/8ths, (I'm 100% metric, so the figures Iunderstand betterare between 7.9 and 9.5 mm...). Anyway, right now and pushing hard with my finger it is more like 5 mm; looking at the notches on the lower belt protection casing it is below the lowest and pushing it it moves less than the distance between two notches. It feels too tight, but again, it is not a chain...
Please check: http://imageevent.com/wforest/dynasuperglidecustom pics 30 & 31
RE: BELT TENSION
Thanks I'm starting to get the feeling that it is really too tight. As a bike mechanic in my early ages I do remember that the tension should be taken with the bike upright and sitting on it, but as I said before, it is my first belt driven.. let's wait for a few more answers before I take any action. Thanks again
RE: BELT TENSION
And wear the belt pretty fast. Another issue is the vibration a too tense belt creates on the equipment.... I'm a pulp and paper machine mechanic and I know some about electric motors linked by "V" belts to pumps and other devices; they vibrate like mad when you change the speed if they are too tight.
RE: BELT TENSION
Thank you Murphdog, checking once more, the figures are 1/4 to 5/6 (I was reading the figures for the FXDWG). Still, the FXDC figures are bigger than what I have; I'm reading almost 5 mm and it should be 6.4-7.9 mm (1/4-5/16)... I have done 400 miles; Is that correct or should I adjust it to the correct gap?
BR,
Spanish Flyer
BR,
Spanish Flyer
RE: BELT TENSION
Definately get the tension guage and adjust as per the procedure and specs in the manual. My '04 Wide Glide manual states that tension needs to be checked with someone of the same size as the rider sitting on the bike and the bike verticalwhile you use the tension guage to check the belt tension, but obviously your model is different as murphdog pointed out. My belt definately feels tight compared to a chain, so that took a bit of getting used to. My first belt too...
