Need help usig NUB tool
Dear forum,
I went and got the NUB tool for replacing valve springs with heads on bike. It is a fine piece of kit, but I have a problem: The valve keepers are stuck to the retainers. When I tighten the NUB tool, the valve simply opens. I have hit the keeper/retainer area with WD-40 and I have tapped it with a hammer with no result. Any suggestions on how to progress here?
With a soft hammer, like a brass or lead hammer, gently tap (not hit) around the edge of the top collar. Then try the tool again. And are you using the supplied hose in the spark plug hole to pressurize the cylinder to hold the valves closed?
The cylinder has to be pressurized (and maintain the pressure) or the tool won't work and if it does, the valve may fall in the cylinder.
Paul
Paul
The following 3 users liked this post by WP50:
Received 49,868 Likes
The following 4 users liked this post by John CC:
98hotrodfatboy (01-07-2023),
Bailey78 (01-09-2023),
Campy Roadie (01-07-2023),
Max Headflow (01-07-2023)
That video doesn't say a thing about pressurizing the cyl.
It shows the hose but no utilization of it ??????
We use to change many a valve stem seal on engines (SBC for one) and have seen a valve or two drop in a cyl. I'm pretty sure you have as well LOL
I took a break outta frustration on one and while I was getting a drink somebody disconnected the air hose I was using to pressurize the cyl and hold the valves in place.
That made for a BAD day for sure.
I'd like to think he was using the hose but it wasn't mentioned at all______ OOOOPS maybe
WP
The air hose is attached. And I gotta say I am pleased with my engine (120R) showing very little leakdown, I can hardly hear anything. Untill I tighten the NUB tool that is .
I have tried to hit the retainer with various tools now with the NUB toool removed and I can't knock the keepers lose from it. I even hit it with my air hammer (with a piece of oak wood between the retainer and the hammer). Maybe 120R is a keyword here, could it be that it's stiff valve springs has got the keepers/retainers more jammed together than usual? I am leaning towards taking the heads off at this point?
JT
JT
